First thought is that the ad is a scam. It claims it's already electric right there in the item title / description:
Customized remote-controlled lawn mower with 750W brushless motor, factory direct sales, featuring powerful climbing capability.
The specifcations state conflicting things (at end of post, due to length).
But one of them claims two 750w "walking" motors, presumably to drive the wheels. Says it has a 24v 24Ah battery, probably to run these.
I'd guess the 224cc gas motor it claims to have directly drives the blade on it's output shaft like any common push mower.
Doesn't indicate that it has a generator of any kind. If it did, it could use that as a starter...but it has an obvious pullstart handle on top, so, doesn't do that either.
It also says the mower itself weighs >330lbs, which seems far too heavy. My heavy heavy-cargo SB Cruiser trike might weigh that much with everything on it. I have an old B&D mower I put batteries on, and together they weigh probably more than twice what the mower itself does, and they're about 35lbs each; if they were all equal that's still only just over 100lbs.
If it actually does weigh that much, it's going to take significant power to climb hills jsut on it's own, much less trying to haul stuff up them for you. You can calculate the actual power required with various internet calculators based on total weight being moved, worst-case slope, and speed required.
A quick google shows that a harborfreigth 224cc engine (same cc as claimed in the specs) is about 38lbs, or something like one of the batteries I have. Even if it's "24v 24Ah" battery is lead-acid, and weighed say, 50lbs or more, that's still another 200+lbs of junk they must have on there to get up to 330lbs+ total weight.
Supposedly track width is only 150mm, yet it says it's cutting width is 550mm. I don't see any blades waving or spinning around outside the mower, which it would require to do this, since the track (wheels) is the widest part of this mower. The photos indicate completely different numbers for this, saying it's almsot a meter wide and long, and half a meter high. But this same image *also* restates the same specs that are in text form in the ad, of the 150mm width.
I would basically not trust that you will get what you expect (well, maybe you're not expecting much...).
that all said, the remote indicates that you could just drive it around, and since the cutting is a gas motor, you could rip that whole engine ane cutting stuff out, and just use it as a remote tractor, exactly as it already is, without electrifying anything else.
If you need to use the battery off your bike to run it...keep in mind that your battery is the wrong voltage, and probably can't supply enough current to run the motors going up a hill by itself, much less having it pull loads for you.
You'd need to test it with a wattmeter installed between ti's original batteyr adn the rest of the system, without any load, going up your hills, to see how much power it takes that way. Then do the same with your worst-case load. Then pick a battery that can supply that power for the amount of time you have to operate it before recharging it.
Make sure the battery you pick is capable of *more* current (A Amps, not Ah Amp-hour) than the wattmeter shows it takes, so that it can handle overloads and will still do the job as it ages.
Make sure it has more Ah / Wh than the wattmeter shows it uses up to do the job you need done for the amount of time you need it to operate. (if the existing battery doesn't run long enough, multiply the readings you do get proportional to the extra time you need).
Monitor motor temperatures to be sure they don't get too hot pulling hte extra weight of your loads; the ad claims they'll work fine up to 130C, but motors can begin to fail (demagnetize, overheat, etc) below that temperature depending on their design.
Specifications
- Hign-concerned Chemical
None
Core Components
engine
- Warranty of Core Components
1
Video outgoing-inspection
Available
- Machinery Test Report
Available
Marketing Type
lawn mower
- Warranty
1
Use
lawn mover
- Showroom Location
China
Applicable Industries
home
- Origin
Mainland China
Brand Name
NoEnName_Null
- Place Of Origin
China
Model
AWY-550
- Overall Size
960*930*560MM
Package Size
1000*980*710MM
- Total Weight
150KG
Package Weight
185KG
- Cutting width
550MM
Cutting Height
20-150MM
- Starting Method
Remote start and stop
Walking Speed
4KM/H
- Gradeability
45°
Walking Motor
750W*2
- Engine Brand
LONCIN
Fuel Tank Capacity
1.2L
- Power
224CC
Oil Capacity
0.6L
- Fuel Consumption
1.2L/H
Track Width
150MM
- Mowing Efficiency
1500M²/H
Lifting Method
Remote control electric lift
- Lighting
Remote control light
Voltage/Battery Capacity
24V/24AH
