drewjet
I finally got my 80-100 130KV motor. I hooked up the ESC and sure enough it works. Now to improve it.
This is intended for my Electrathon racer which currently has an original Etek brushed motor in it. Currently I can go about 30 MPH on around 1000 watts. I want better. If you don't know about Electrathons, in a nutshell it is a 3 or 4 wheeled electric vehicle that is raced to see who can go the furthest in 1 hour on 1KWH of batteries.
My calculations say that I need a KV of about 90. This is calculated from running a 20" tire 48 volts and using a 12 tooth sprocket up front and a 92 to 98 tooth extron on the wheel single reduction. Since I am pulling an average of 1000 watts, I don't believe the lower Kv will hurt me as I don't want or need max power out of this motor.
Fill is OK, but could be better
It is mrked Y8 with a sharpie, I confirmed it is 8 turns, but it is connected Delta
I am guessing that I need 11 turns to put me in the ballpark. I only need to be close as I can change gearing within reason to get the speed I want. Anyone care to confirm?
