carlhirsch
- Joined
- Jun 4, 2021
- Messages
- 3
I've got a Bafang+Gates+Rohloff bike from FLX. It's a fun throttle-y deathtrap, but I find the gearing doesn't allow me to leverage pedaling at high enough speeds.
I'm trying to replace the rear sprocket with one slightly smaller, but my (very ebike friendly and skilled) local bike shop has been unable to get the lock-ring loose to make the swap. I've procured Rohloff's tool #8518 but even using that we're making no progress. LBS states they're applying at least 100nm to no avail. They're speculating overtightening at the factory but I'm really starting to suspect they applied Loctite.
LBS states: "If they had a stamped spanner type version of the tool, we'd be able to get it, because no force would need to be applied toward the center of the axle, only in the direction needed to remove it. If there were a way to secure the current tool to the axle, we'd also be able to get it w/ out issue."
Has anybody run into this before? Is cutting off the lock-ring an option?
