DaveLakeMary
I have an older 2016 Chinese bike. I am the second owner. I have maintained it well for the 4 years I have had it. The 810 panel wore through. For awhile I kept it saran wrapped so I could ride. This week I ordered a new S810 five wire panel. The bike, once up a time, had a headlight. So the panel had the on/off, light and mode switches.
I purchased one on Amazon that I thought would be the same. When I received it, the panel had the 6km switch instead of the light. The single sheet instruction, however, said light. The seller said it would work.
It does work ... but differently than the original.
Light. Never used it. Completely took it off the bike.
Mode Low Original - When pedaling, it launched hard and immediately went to about 8 mph. To me that was fast. But never having an e-bike before I thought it was normal.
Mode Low New - When pedaling the motor does not engage. It does engage with the throttle.
Mode Med Original - Launched hard and would immediately accellerate to 8-10 mph. Speeds would be a bit higher than low when pedaling in low.
Mode Med New - Launches to a comfortable 5/6 mph. Also works well and as expected with throttle.
Mode High Original - Not much different than medium.
Mode High New - Launches similar to new medium with a nice increase in speed with the throttle.
6KM switch - When depressing the and holding the mode switch, after a couple seconds the motor starts and begins to accelerate in all modes from idle (no pedaling or adjusting the throttle).
The first power led blinks as well. I thought that might indicate a low battery and fully charged it. No change.
Although I could live with everything as it is, I believe the Panel/Controller somehow needs parameters changed. I have read in other posts about the controller needs relearning. However I have had no luck finding any instructions or videos to do this.
Any ideas or links to videos/instructions would be a great help.
Many thanks, Dave
Many thanks, Dave
