Does the brown wire go into a 3 way plug together with a black and red wire?
If it does then I think it is for 0-5v ebrake throttle signal. I can’t help where it is supposed to be soldered onto the pcb though, but It shouldn’t stop the controller and display from turning on.
Have you checked that you still have 72 volts from the battery after replacing your fuse?
I have found that it is quite easy to overheat the QS205 if I give mine a lot of abuse with lots of hard accelerations coupled with hard ebraking and I’m only using a 72100. My ebraking is set at 30 amps, operated via the brake switches which I think is fairly mild. I don’t have an ebrake throttle.
I kept on blowing hall sensors when the motor got hot, so I have replaced all 6 hall sensors in the motor with new SS41 rated at 150C.
And I replaced the KTY 83 temperature sensor in the motor with an NTC 10K temperature sensor and have a separate temperature meter with an alarm set at 90C.
I also fitted an NTC 10K inside the controller next to the existing temperature sensor to independently monitor the controller temperature and set that alarm for 70C.
Now that I’m keeping my temperatures down it is operating reliably.
All of this was done on a brand new motor and controller while ironing the bugs out on a new build.
It may also be worthwile for you to check the brake disc screws haven’t rubbed on the motor cable. Mine did this on the test stand and severed the insulation on a couple of phase wires, so I had to order a spacer from Ali Expess to solve that problem. I was lucky the wire’s didn’t short together and blow the Mosfets. The orange coating on the motor cable seems to be as soft as butter.
I had to cut the motor cable to remove the damaged section and rewire it to the motor. The spacer is available on eBay for around 12 dollars if you are based in the US.
QS Motor 205 273 50H V3 V3TI Spoke Hub Motor Brake Spacer Hub Motor Wire Protector from Discs. We will do our best service to help you.
www.ebay.co.uk
That’s all part of the joy when doing a diy build. Someone on this forum did write that the QS205 is “a difficult motor to work with“ and they were not kidding. But it’s great when you can get it to run right. It has so much torque and speed.
