SABVOTON 72150 throttle/lock/ignition bypass
noonedoesnt
10 µW
Hi all, I received a sabvoton 72150 with a cycle analyst plug, i am wondering how I can turn on the controller without running the default chinese throttle that has a lock.etc. I plan to plug in just a thumb throttle into the CA. Normally all three of these go into that controller, the two 3pins are for throttle and 3-speed switch, the other 2 pin with red and orange wire i assume is for the lock to the ignition. Every wiring diagram I find is different, and my controller does not have a separate ignition switch.
How can I connect/short this 2 pin to power up the controller without a lock? Thanks :)
(On a side note, the alarm/lock wiring, do i need to short any of this too? I don't plan on running an alarm/lock)
