hello
could you pleas help me.. over 120kmh i get overcurrent error..it is the same when i set rated dc current at 100amp and rated phase current at 150amp and max phase current at 300amp protect at 600amp.anything i try at low settings or anywhere its overcurrent error after 120kmh.it should go till 200dc 450phase and 550 protect..its unlocked so it should go even higher l, but i didnt try it becouse even at low setings it makes this...till 120kmh with full throttle is everithing fine...then it blocks the motor and system error/ over current error comes flaged. i have sabvoton 72200 unlocked and 5000watt motor 75h magnets with high speed kv hub motor.. it should go till 150 kmh so 3300rpm on 11inch tire..what should be the problem with the setup ? could you send me parameters or something ? is there anyone that knows something to help me..iknow its Ebikes here but its for an e scooter, but its e bike controller ..i have 2x sabvotons on my scooter, crazy power but its not safe if motor blockes at 120kmh...
with best regarrds
ozvaldic ozbej
with best regarrds
ozvaldic ozbej
