jakmobile
I recently acquired a fully assembled s73 clone that has a Sabvoton SVMC 7280(M) and a 16" hub motor that is supposed to be 5000w. When I first received the bike I wanted to replace the brakes/calipers with 4 piston brakes, which I've done but while in the process I decided I want to understand from top to bottom how the bike functions and how to configure the controller and motor. When I got the bike, the motor was working/ish but I had to replace the display (old one was fried) so I realized at that point how little I understood how to configure these devices. My background is network/security/cyber engineering so I figured that I should be able to figure out how to do a basic config.
Not so much. I've replaced the display and that's working fine, and being OCD, I decided to go through all of the wires coming from the controller and label them so I knew what did what. The bike also did not have any way of locking it so I decided to replace the twist throttle with one that has a digital battery display and a physical key. The original throttle had 3 wires (red/green and black) which I connected to the same color wires coming from the controller that the other throttle was connnected to but but I'm not getting much speed out of it and so I've been trying to determine where the other two wires go to and if if they have any effect for the throttle response. The remaining two cables from the throttle are blue and yellow. And I've been told that blue goes to "orange ignition to battery and yellow goes to "D+". I don't have any issue with splicing cables but I want to confirm where I should be splicing them and what should I expect as a a result of these two connections? I would expect one to actually illuminate the display and I'm not sure about the other. Would someone mind helping me figure this part out?
Sadly I haven't been able to complete that task, nor have I been able to use MQCON to configure the controller and motor. I've downloaded the MQCON software to my iphone and purchased a decent bluetooth adapter from Amazon to do the configuration and that's about as far as I got. I've disconnected what I think is the display connection and have attempted to connect to the bluetooth adapter via MQCON but the app isn't even seeing it to connect to it. I've deleted and reinstalled MQCON but nada, any idea what I'm missing?
Once I can get these two issues figured out and I can do the hall test and angle (I somewhat understand what that does but I couldn't explain it if I had to. I also seem to have some ghosts in the wires as the brake lights do not work, the turn signals don't flash and I think that's about it. haahahaa.
Anyway, would anyone be willing to help me out with this? I'm sure all of these questions have been asked in some way shape or form before and i've tried to do research before asking for help but I think I'm at the point now where I actually need feedback and more than what info I'm getting from the current youtube videos out there. I know that this website prefers these discussions to take place in the forum but if someone is willing to help and would prefer talking on the phone or some sort of virtual call, I'd be down for that. I'd even be willing to paypal some cash to you if you can help get this bike back to it's prime.
Thanks!
Thanks!
