Hi e-bike comunity!
I have the problem that my ebike (Sabvoton SVMC 72045 + Cycle analyst V3 + 3kW-Hubmotor) does not provide the full power all the time. After about 10 min, the Power response dropps signifficantly. Crossing a street gets riscy because of poor power at low RPM or start driving. Start to drive in a slope-no chance! The first 10min after power ON the power rises quickly to 2,5kW and the feeling is wow powerfull.
Configuration: --> blease note--> Sabvoton = SV ___Cycleanalyst = CA
The SV is conected with the CA regarding the wire diagram. A key switch interupts the Battery+ to CA as well as to the ignition wire of SV. A hubmotor is connected to the SV. Just one Hallsignalwire ist conected to the CA (for speed meter).
Tests:
--> direct connect of Throttle to SV --( CA-modifyed Throttle -disconnected) --> no seccess
--> e-brake throttle disconnected --> no seccess
--> e-brake low switch activated and disconected -->no seccess
--> Ingnition - wire interupted --> success !!! looks like a reset and has the same efect as Power OFF/ON
Doubts: The software diadnosis screen shows the status ...(flox weakening enabled) but I disabled it in the setup ???
The software diadnosis screen shows no RPM and no Throttle signal Volts??? But when I actuate my brake throttle the status changes to ebrake and the brake throttle signal is shown .
I tryed a lot but I have no idea what to do next.
Hope for someone who can help me now.
Thanks!
Tests:
Thanks!
