Drunkskunk said:Are you powder coating the parts, or just painting them?
safe said:Drunkskunk said:Are you powder coating the parts, or just painting them?
Just regular gold spray paint.
Geebee said:How do you explain to the officer when you get pulled over for doing 60 when you are meant to be limited to 30? At least if you have pedals you can say the motor was only assisting cough, cough.
Mathurin said:Beware that if it pops, a wide tire on a narrow rim is more likely to get off the rim and jam the wheel. It's preferable to mount wide tires on wide rims. Sorta looks like you're running 3 inch tires on 2.5cm rims, you'd also get less side to side play with these tires on wider rims.
Toorbough ULL-Zeveigh said:I'd really like to see how one could adapt a standard fork for the second caliper. That would be defiantly come in handy.
fechter said:I've seen a disk brake adaptor that has freewheel threads on one side and a standard 6 hole pattern on the other end. Wish I could remember where.
Lowell said:Yup, thanks for posting the pic. Picked mine up from ebikes.ca.
CGameProgrammer said:Also, still echoing my previous request of a video of your bike.
safe said:Lowell said:Yup, thanks for posting the pic. Picked mine up from ebikes.ca.
Excellent!
Wow, at $13.50 that's a good deal. I've already laced up the wheel and it's all done as far as the hub, but if I were to do it over again I'd just buy that adaptor. Is ebikes.ca somehow making their own? I wonder who makes those? (it appears to be a relatively rare item and I've even seen messageboards talk about the "impossibility" of finding such a thing :lol: )
