Samsung 20R vs 25R
mchlpeel
Lincoln, UK
I'm looking to buy a battery from em3ev and have 2 choices
The packs are 50.4v nominal and I want to draw 60amps max from them
Pack 1
Samsung 25R 22.1Ah
Pack 2
Samsung 20R 17.5Ah
Would the packs deliver 60 amps with no detrimental effects or is one better than the other.
From a quick googling - looks like they're both close to 10C. The 25R does 25a continuous discharge and the 20R does 20a.
...I see the 20R range between 20-22a and the 25R range between 20-25a depending on the site.
You are saying that one battery cell of 25r can crank out 20-25A?
So a 4P pack will spit out 80-100A at whatever voltage your Series string is at. With more P you decrease the voltage sag.
From what I gather
25r = 8c
20r = 10c
So take your pack Ah and times it by the c rate above to find max continuous current
Simple818 said:
No problem doing 60a. Will barely sag. Probably sag like 2 volts
Per the spec sheet ( attached ):
A 20AH 25R pack at 4C ( 80A ) will drop from 3.61v nominal to 3.44v nominal.
That's a 0.17v drop per cell.
At 4C and 14 cells in series, you will see 14 x 0.17v = 2.38v drop when you hit it with a 60A load.
Yeah, you're just about right on the money there for a 3C load.
8C performance is bad and the cells become 3.27v nominal, as low as lifepo4.
0.34v x 14 = 4.76v of sag across your ~50v 20ah pack. Your cells also go from 30C to 95C.
Yeah, don't do that.
  • 131101_Introduction of INR18650-25R.pdf
