No, because I converted using a rear hub, I left the front fork, just replaced the wheel/tire to match the rear; the fork is a Zoom, which is sort of the de-facto industry standard OEM suspension fork that you see on just about every entry-level bike and while it's not super, it's not horrible either.. The bike is designed using a narrow quill steerer, so my alternatives for replacing the fork would be to convert to non-suspension rigid forks (not for me), special order something (and about the only replacement available other than another Zoom is from RST and it's the same spring-polymer type that the Zoom is, and pretty similar quality-wise), or to convert/replace the headset to a threadless, which would give me access to gas/oil-filled suspension forks, but since I like my handlebars set up quite a bit higher than most people, the extra work required to convert a cheap bike frame, the lack of easy height adjustability of most threadless sets, which have to be cut to length and stacked with spacers, was just not appealing to me, not to mention that I'd already spent a fair bit on the rear hub kit and also a new front tire and rim, so I really couldn't justify another $400-500 on top for something that didn't really need to be replaced..
I'm not sure I agree about rear suspension, at least not 100%: while I do think there should be something to compensate for the extra weight of the motor/battery pack in the back, I don't think the rear suspension of the popular style with the hinge and spring in the middle of the bike is the right solution.. WIth a rear hub, when you accelerate on the motor, this sort of bike suspension allows it to basically "fold up" and tip the seat, especially with a high torque motor.. If you adjust the spring tension to prevent this, then it's so rigid as to not make much difference vs a "hard tail" over road bumps.. Other than going for some sort of independent rear suspension with dual shocks like you have on motorcycles, I can't really think of a way to make a "safe" e-bike rear suspension..
