TricycleMichael
- Joined
- Oct 16, 2020
- Messages
- 36
It has been written on ES about the problems with the Schwinn Meridian tricycle rear axle. Noise, grinding sounds and bearing failure. If the four rear axle bearings are even slightly out of alignment the axle will not slip in perfectly and the pressure on the bearings will cause a failure. Also, the bearings spacer tubes can get out of adjustment and make noise.
Found a vintage Meridian that had this problem. Axle slips thru two bearings but hangs up on the third. One solution would be to align the axle tube, maybe bend it or weld a brace to maintain the alignment.
Forcing the axle that is just a tiny bit off can be done but caused a lumpiness on rotation and I’m sure would blow out the bearings. Maybe 200 miles. BTW replacement carriage is not available from Pacific Cycle (older design) and finding another would likely have the same problem.
The fix:
Removed the bearings and spacer tubes, replaced the bearings, cut the axle in half, slightly drilled the axle for the locking collar set screws to be sure they would be secure. Reassembled the whole thing and because each axle is only using two bearings they rotated perfectly smooth. Buttery smooth.
I ride vigorously and after 1200 miles everything works smoothly. I was concerned about horizontal pressure on the bearings because I left the bearing separator tubes out and the bearings are only held in place by the recess in the carriage axle tubes. The double nuts were tightened “finger tight” and showed no horizontal play after 1200 miles. Used Lotite blue 242 on the collar set screws and double nuts.
The trike was likely built in Chicago before 1968 or whenever things were moved out of country. Has the bulb frame. Like it so much I decided to make it cool. Kind of a hot rod. Replaced the geared motor with an old Crystalyte RoadRunner 4820 on a 24 inch fork. Very fussy about the front fork, inspected the dropout for stress - none - have a spare just in case. The patina is original and I blacked out cranks, fork, handle bars, and other stuff to make it unique.
It will go 25 mph with a 52v LiIon battery. Usually ride between 8 and 15 around town.
Original post two years ago search ES for: “Meridian Tricycle Axle Noise”
The fix:
