Hello guys,
This is my first post here, but I was reading the forums for a bit... It was a great inspiration!
I am building an ice fishing electric powered auger, and I need an advice on my setup. I have a planetary gear 1:10 reducer (gear head) and aiming the speed of the auger in 300-400RPM
After some research I have this setup in my mind:
For the motor - Turnigy SK63-74 170Kv
For the battery - 3 Zippi 6s 20c 3000mA in parralel
For the ESC - Hobbyking SS Series 190-200A ESC (I don't need any flexibility - auger spins at full power all the time)
Obviously, I will be using it in cold, so I need an extra Amps on a really cold days, so that’s why I want to use 3 6s packs in parallel. Also, I plan to insulate the batteries from the cold, but it's close to impossible in Canadian winter conditions
The only question I have is the motor - will it handle the bursts of 180A for a minute? The auger is working for a short time - it takes no more then a minute to drill the hole even in the thick ice... Weather and water proofing of entire system shouldn't be the problem.
Am I on the right route?
Any feedback is appreciated and welcome!
Thank you!
Max
Thank you!
Max
