Gordo said:
Lock said:
Actually I was thinking a diamond shape so when his fishing buddies walk over they go WTF! Betcha their holes are all round and kinda...boring.
The idea isn't to melt the whole hole, just the edges then extract the core.
Lock
Lock;
You might want to go look up "heat of conversion". It takes a zillion watts to convert 1lb of ice to 1lb of water. With a perfect heat sink all around your brain fart element, you might as well power it with beer; ie get 6 guys to pee on the ice in a circle. :lol: If you have ever tried pulling a block of ice out of a lake, it ain't easy. The auger is the way to go.
Just to quantify Gordo's point. It takes 333kJ to melt 1 kilo of ice if it's right at the conversion temperature of 0°C. 1 joule = 1 watt second, so melting that kilo takes 93wh, and assuming 75cm thick ice (about 2.5ft) that kilo ring of melted ice would be only about 3mm wide for a 15cm (6") diameter hole. Even if you could get that ice core out with a perfect cylinder, his battery pack could only cut 2 holes. Apparently those ice fisherman use lots of holes, since the electric one I saw claimed 45 holes for about the same size pack. That makes the auger is over 20 times more efficient than cutting by melting a 3mm ring.
Then there's the giant block of ice as a heat sink, so even if melting a ring was reasonable, the water would quickly refreeze behind it. To come close the auger method it would require a sub-millimeter wide ring to be instantly melted and the core ice cylinder extracted in that same instant for it to work.
From the video I saw, those motorized ice augers are impressively efficient tools perfect for the job.
