I have picked this bike up for my first ev conversion. The bike is a shineray xy 125 cg 2006 vintage which had blown motor and been sitting outside in the weather
So got it back home and started to strip down. Everything seems in pretty good shape frame is straight , swing arm bushes all good, wheel bearings ok and even front brake is working
I have got the weight down to 50kg which leads me to the first discussion what motor kit combination to go for
The bike specs
It is going to be a mid drive set up.
At the moment it weighs 50kg, wheels are 16 inch rear/ 19 inch front. Rider weight 80kg ( on a good day :wink: )
The conditions the bike will be used for is mostly flat ground on grass and trails with about 10 degrees hills and i only looking for about 50kph and ideally 30km / 50km depending on the battery i can fit in the frame ?
Have come up so far with 2 options as i want a plug and play
First, QS 2000W / EM 100 72V Kt or the QS 3000W / 150 EM Kit 72V .So basically I would like to get to top speed quickly.
I probably forgotten some details but this is where I at the moment. Look forward to any suggestions
Cheers
The bike specs
Cheers
