flyingbeekeeper
I've got 3 sub par cell blocks on a BMS, I'm confused why it can go up to 4.16 but not 4.20v. Any ideas?
First, I know that 3 cell banks are weak, and replacement of said 3 will likely fix the issue. I'm not wanting to know why my pack is not hitting 4.2v, I want to know the controller logic that won't get it up to 4.2
Second, the homemade pack is a new build with old laptop cells (18650) that passed (13S2P) and the BMS hasn't proved to me it can hit 4.20.
Third, I can take the pack to 50% DOD and plug it in and it will fairly quickly rise to 4.16v. BUt I can leave it charging for 3 days and still be at 4.16. So I'm confused.
Fourth, I can charge the piss out of a cell group and take it majorly out of ballance, like 4.26 on one group and the BMS bleeds it down until all are 4.16 again.
Fifth, I'm an EE and have a clue. But explain to me what you think the BMS may be doing, as if I were five.
The question is not "what is wrong with my pack?", I'm pretty sure I know the cause. The real question is what is the BMS doing and why can't it get to 4.20?
I've bypassed the BMS charging cable and put on balancing leads and balanced the pack to 4.20 using an IMax B6. It gets to 4.2v and holds with the BMS connected. The weak 3 banks decay to 4.19 but stay alright there. So the cells can get there, but the BMS can't. Any ideas what the BMS is doing?
Specs on the Signalab
13S
Model: BMS13LI
Protection Circuit Module Specifications For 46.8V Li-ion Battery Pack, Different with normal PCB, it provides equilibrium function after battery pack is fully charged, e.g. PCM will detect each cell's voltage and trim higher voltage until other cell's voltage reach same,therefore allow Li-ion cell has longer service life. Also the PCM will provide the following protections:
* Balance each cell at Max. 4.2/cell ( required voltage tolerance within 0.2V for each cell)
* Overcharge protection voltage for single cell: 4.35V +/-0.025V
* Overdischarge protection voltage for single cell: 2.40V +/-0.08V
* Continus working current: 30A
* Overcurrent detection protection: 50A ~ 60A
* Supply current: Max 30uA
* Short circuit protection
* Protection circuitry resistance: <=50mohms
Charge current : <=5A
13S
Model: BMS13LI
