Hi all,
I have a need for black 16" 349mm 36H wheel rims (same as used on Brompton) and they seem to be virtually impossible to get hold of in this size, (unless anyone knows a UK-based supplier?)
I'm converting a Mezzo which uses the same wheel rims, but my bike is black so the silver rear rim I have had my hub motor built into doesn't match the front wheel. This was a custom wheel build as you can't 349mm rim hub motors ready built up. I didn't think about the rim colour at the time! The wheel rims are readily available in UK in 349mm 36H in silver and come in brushed aluminium, but as I said, black, not available oddly.
Right, so here are my options:
1) Use the original black wheel rim which came with the bike, and get the extra holes drilled for motor hub spokes. I imagine this would not be easy to do by hand with an ordinary drill and mean going to a workshop or specialist factory?
2) Spray-painting a silver wheel rim black or using some other black paint products. I need a matt finish and obviously it needs to be durable and not scratch off in 5 mins! Is this viable? I'm thinking with perhaps with an undercoat, some matt black spray paint and a matt/satin finish lacquer overcoat it might do-able? I know there are other paint products on the market though, eg: Birchwood Casey ALUMINIUM BLACK Metal Finisher.
3) Taking the silver rim to a factory workshop that specialises in anodising aluminium and give it the acid bath powder coating treatment. I imagine this would be the most expensive option.
Which option do you guys think is the cheapest and easiest? Perhaps you would approach this problem differently?
No "change the front hub to silver and live with the silver" comments please! It's simply not a solution.. the bike is black, it has to be kept original looking, and the wheel rims have to be black.
