NeilP
1 GW
I know what I am asking is a balancer unit..but all the balancers I see are digital, with displays, , programable etc etc. Just wondered about a simple minimal component fixed voltage, discharger that you set to a fixed voltage...drops the cell to that voltage then cuts out
I was wondering a very basic circuit..say a reference voltage zener or similar and trimmer, a FET and power resistor, no doubt a few control components, no external power source, powered from single cell.
The idea is a single stand alone circuit that drops just a single cell to a reference voltage. and then if you want a 10 cell balance unit..you make up 10 of them...or use one or two on any cells that are getting a bit high while bulk charging.
I have no theoretical knowledge to knock out a schematic, so if any one could show me a simple circuit that would be great.
My current method is a two pin JST plug, on to a 'Y splitter" one side to a bulb and the other two a celllog with an alarm set to my required voltage. I just unplug the bulb when the Celllog alarm goes off.
