Hey Cold-E
... Ping packs come w/a BMS.
Whs measure absolute capacity... available stored energy as how many watts can be delivered in one hour. Volts times amps give ya watts (power) but each is important with plusses and minusus. More Volts gives ya more RPMs - higher speeds - while more Amps gives ya better torque - acceleration and hill climbing. More amps means more losses (heating of motor/electronics/wiring/connections...) So it's a little dance juggling the mix of volts and amps to get watts.
Also, the (SLA) batt manufacturers LIE about their batts (Ah ratings.) Their ratings are based on a discharge rate over TWENTY hours. In an EV world life ain't like this. Faster discharge rates means ya see less actual Ahs from the batts. Then there's the fact ya shouldn't run the batts down below 20% of their rated capacity w/out reducing their claimed life (number of cycles, discharge plus recharge usually claimed as 300) and really running them down to only 50% does mean a longer life (more cycles before they get too tired.)
Then there's cold weather... where the Whs ya see get cut again.
I have a LiFePO4 pack to play with now, but if yer sizing a SLA pack, basically ya need to figure out the Whs ya need to get the job done. Lots to consider there, including the fact that power needs to cut through the air are not linear. Once yer hitting the high 20mphs (or hit real head winds) power needs per mile rise quite a bit (slowing down takes longer to get places, but you consume less Whs per mile, so have longer range.) What is your mix of pedalling versus battery really?
Then double this to allow for not running the batts down to empty. Then double that again to allow for cold batts in winter... Then decide on the split between Volts and Amps. (Actually, really I have this backwards. Figure out how many volts (RPMs) ya need, then how many Amps (how much ya want to show off yer power-assist) THEN figure out how long ya need to be burning up these Watts - watthours.)
Then add some more Whs to allow for play, `cause you'll end up spending more time having fun w/yer power-assist bike than you imagined
And yer SLA pack isn't fresh lead forever... allow for the fact that after 100-200 cycles they will already be feeling a bit tired compared to when they were new.
Gawd I love fresh lead... the way the vehicle feels alive again when ya plug in a new pack after the last daze and weeks of trying to squeeze a bit longer life out of the old, tired pack just replaced!
lL0K
