If one wanted a small efficient gasoline engine to PM generator, today!
Sorry there's no such thing.
The surface area of the combustion chamber increases as the combustion chamber volume, in cc's here, decreases.
The smaller the engine, the more inefficient it is, due to heat loss through the big surface.
For our power needs we're looking at engines as found in Weed Wackers (cheap), chainsaws (?) and RC aircraft (not).
It doesn't end there.
Increased friction..? (..? is often a 'note to self)
Pumping losses below the single piston.
In a 2 cylinder, 1 piston is going up while the others coming down, so the air beneath them on has to move 1 cylinder over
There's nowhere to go in a single cylinder.
Vacuum is currently used to ameliorate that. (sucks oil out between the rings? Lubrication?)
(2 Reed valves turn it into a supercharger..!One in and one out to the intake.
Lubrication becomes an issue. That much oil in your intake wont work. Centrifuge..?
Or put a 4-stroke head on a 2-stroke and lube it like a 2-stoke.
While that might help efficiency some and power to weight, I digress!
(Oh ye; Or just go 2-stroke. Constant rpm makes it way easier to clean up a 2-stroke.
The oily exhaust makes it so you can use structural frame tubing as an exhaust and Quarter wave resonator saving weight. That may work for other engines too depending on metal choice. But I digress again! )
Point is small pistons just aren't as efficient.
A rotary engine's power stroke is in the same... lobe I think? Its like the sleeve and head stay hot from constan power strokes if you get my meaning and its just a cool piston every time type thing
If the combustion wall runs hot that should make small rotaries more efficient than small piston engines..?
Friction is lower too IIRC? No reciprocating.
They're high maintenance so guys who enjoy building engines have them...
They do run smooth (low vibration) and are pretty compact.
This video of a tiny 1.4hp rotary makes you want to put gears in just for the sound!
I NB that high pitch noise is easier to damp. and constant noise easier to tune out. (for all engines mentioned)
There's that other rotary too..?
Linear engines:
Very efficient!
But you wont find one at the hardware store.
I think maybe the DIY trick here is to turn the virtual crankshaft like an electric motor would, sort of linear-ised...
Change to generator PDQ every 4th stroke. To supercaps 1st..??
Then start playing with the CRANK profile..!
A "We know how crank engines work so stick with that initially" kinda thing?
Lets not forget that everything from optimal AF ratio and spark timing to cam profiles and tuned length exhausts and intakes can all work together at their optimum, all the time..! at constant rpm,
EASILY!!!
Even with a cheap ol carb etc.
This works for all the above engines.
So which type and why???
Engine to generator:
Direct drive with a rubber coupling is most effectient, but both the engine and generator have optimal rpms.
Finding an engine and generator (PM motor?) that are optimal at the same rpm is no easy task however!?
So chain or belt drive makes things easy here. 96% efficient?
What would you guys do?
The generator:
Thats all up to others here, far more qualified than I.
I'm at sized for average KW, PM motor and engine..?
Linear engines:
Very efficient!
EASILY!!!
The generator:
