Probably vivax assist...but your seat tube needs to be long & wide enough
http://vivax-assist.com/en/produkte/vivax-assist-4-0/vivax-assist_4-0.html
Sophisticated motor power is hidden in the bike‘s seat tube. It only weights 1.8 kg (inkl. battery). Press the button and the motor delivers 200 watts to the crankshaft. Press the button again and the motor stops. Without motor power the bike functions as normal without any kind of resistance. The Lithium-Ion high-performance battery, which fits into a conventional saddlebag, provides you with motor-assisted cycling lasting for min. 60 minutes (6 Ah) or min. 90minutes (9 Ah). The special design of the drive unit allows it to be built into any bicycle frame with the requisite seat tube internal diameter of 31.6 mm or 30.9 mm and is therefore invisible on the bicycle – except the on/off switch, which is unobtrusively located on the bar end.
Aluminium or steel frame (carbon on request)
Straight, continuous seat tube
Seat tube inner diameter of 31.6 or 30.9 mm
Shimano Hollowtech II crankset – with outer bearing shells (not pressed in)
Seat tube should be as central as possible on the bottom bracket
Minimum length of 62 cm from the middle of the crank to the saddle or 51 cm with a shortened seat post
