Smooth Controller Recommendation For BMC V3
jtmjtm2001
Salem Oregon
I have busted the retaining pin that keeps the planetary gears from spinning around due to lack of a soft start. What is the best controller that has a good smooth throttle? Thank you. John Morris
The retaining pin I meant the key that goes in the keyway of the axle of the motor. The controller I have now is a Infineon I bought from ebikes.ca is very "jerky" that is either very slow medium or fast. I can overcome this issue by pedaling and start real low on the throttle and work the way up and slowly letting off the pedal. It is almost impossible to maintain the speed I want. Thank you.
