billvon said:However, undertightening (so you get the axle moving back and forth slightly every regen/accel cycle) can be worse.
1) You are loosening the nut a little every time, so you have to keep tightening it daily.
2) Every time it hits its limits it wears the contact point a little more. Wear it enough and it will cam out.
You must be aware that it works like this:
If the axle nut is loose or just tightened a little bit, then for instance the axle would be able to transfer an alternating torque of 200Nm.
Now if you tight the nut as hard as usually those M14 or M16 threads needs to be tightened, then the maximum torque you can transfer over the axle WILL BE WAY LOWER as the 200Nm from before.
If there is some play in the dropouts, it will not help much if you further tight the axle nut. It will always move back and forth no matter how hard you tight it because to motor has simply to much torque.
What you should do instead is removing the play by adding thin metal sheets, or rebuild the dropouts (a clamping with two bolts would be optimal).
@ chalo
yes you are right that this axle is way to weak for the torque the motor can produce.
it probably had been abused too with that big 280A controller , but nonetheless there is a weak point where it broke because of the bore for the wire.
