Snow plow using electric KMX e-trike?
Doctorbass
Quebec, Canada East
Winter coming in few month and i'm wondering if it woudl be amusing to try to plow the snow on my garage parking by installing an agressive motorcross tire 3.5" ( 16" rim) on the rear motor and a plow in front of the trike :mrgreen:
I searched for any ecisting idea and found this pedal powered snow plower
As well. i would protect any metal part from rust!
This guy did alot of research!:
http://www-bdnew.fnal.gov/pbar/organizationalchart/peterson/snowplow_files/Bike_Plow.html
Bike_Plow.html
Doc
Great Idea!! :D
The pull behind plow is simply genius! Best of both worlds, you get to ride in the snow on your bike, AND clear the walk at the same time! 8)
Of course it's only going to make a narrow path and can't handle deep drifts, but what set-up on a bicycle can?
If you do use that snowmobile track, will you still have a tire up front?
Maybe then you could call it a Snomobike! :mrgreen:
I am now looking for some 120 track
120 seem the number for the serie of these kid snow mobile like:
XC-120
ZR120
Mini Z
Z120
Hard to find a great price!!
most of the track i found are at 300$ !!
and i need the assembly too!
Any help will be appreciated!
Doc
Make a snowplow out of a VW bug, converted to electric of course. The tow bars that attach to the axle would be the starting point for the plow.
doc007 said:
Another interesting traction technology you may be able to adopt:
that thing is nice.. but on a soft and deep snow it will act like a chainsaw! :lol:
Doc
Doctorbass said:
I found a manufactur for the track and assembly
they are st 10km from my home and they are teh manufactur!! 8)
http://www.adboivin.com/Afficher.aspx?section=177&langue=en
I also found the assembly and all parts availlable here:
Doc
Doc,
I'm researching tracks info too for my e-sledge idea. Thanks
But where are you planning to install the motor and which type ? Hub ?
I always start to find the design with the least components. So I was thinking to install a hub motor inside the track , actually fitting it directly with sprocket. Crazy idea ?
Doc
Doc,
Yes, Hub motor INSIDE the track is one of the idea i had, but problem is that i would need to use a very small diameter motor unless i cut the actual swing arm of my etrike to let enough room for a 5300 motor diameter
Doc
