Solar Breaker Research
methods
1 GW
Santa Cruz CA
Goal high level: Low cost "contactor" (in this case breaker switch) suitable for 150V @ 100A continuous DC to be used as part of a low cost, IP67, final stage in a modular BMS that spans 4S to 30S. We want mosfet drive quiescent current (so... microwatts) with contactor simplicity and robustness.
Looking for: Quality brand name that sells in volume (we need these cheap, so not the top of the line) where ideally a single form factor covers multiple trip ratings as with a standard breaker
Big Moose suggested in another thread the novel idea of attaching a solenoid to a breaker to turn it into a latching contactor.
You would manually set it.
It would break in the case of short circuit
The BMS could force it to break in the event of XYZ via the solenoid
It would always require manual reset... and this is fine... because nobody should be bouncing off of BMS limits. The Controller should handle LVC, the charger HVC, and precharge for big spikes.
(Hmmm... now that I think about it... eh... we will need to be able to reset that quickly)
Comparable DC contactors go for about $100 but draw 1W to 2W continuous to operate.
Comparable LATCHING DC contactors go for about $150 and draw nothing
Comparable Mosfet stage... can get really expensive... if we want it to be as reliable as a contactor or breaker against gnarly capacitive loads etc. Maybe not expensive in production but certainly expensive in Engineering design hours, qualification, heat sinks, ... meh. So voltage sensitive as well... and a lot of work in production.
Starting to dig now.
Will start with major retailers and work backwards for some economy of scale choices.
We want to make a 150VDC 100A latching relay for an order of magnitude less than Gigavac (who already totally undercuts other high reliability brands).
-methods
From this video...
(Where DC vs AC breaking is discussed)
The following breakers are offered
Large frame (Big current)
Panel mount
Din mount
Panel mount is smallest and rated for 150V 100A @ $20
"guy" in the video claims full switch rating under load all day long
-methods
Under $15, no tax, and some specs
Too good to be true
https://www.invertersupply.com/index.php?main_page=product_info&products_id=5859&gclid=CjwKEAjwsqjKBRDtwOSjs6GTgmASJACRbI3fY8gOT6e3BbukhFSC7VyoFK5iFAzRcQLJnXQzqx-xAhoCv9_w_wcB
-methods
To bound the search for solenoids...
we need about 5Nm and probaly a centimeter or two
We want 12V but whatever
Here is one for $10 at Adafruit (and they generally have very high prices but give a lot back) so that sets the expectations
Breaker $20
Solenoid $20
Housing $20 (after assembly, water proofing, accessibility, ...)
Redundant trigger circuit, connectors, etc $20
We are creeping on the cost of a standard latching relay.
We could still meet requirements by using a NO contactor driven by a Nchannel high side driver (with external shunt) for fast opening in short circuit conditions.
Every battery will just require a 2W solar panel :mrgreen:
ah - found it...
We can just hot-glue 6 of these bad boys all over the <situation> and ignore our 2W burn rate :roll:
-methods
