spinningmagnets
100 TW
These have been around for a while, but I have noticed a couple new developments that are very beneficial. I thought a few readers over the past year may have not seen them yet. Most can be built cheaply and easily. But PLEASE, exercise extreme caution when asembling any type of solar concentrator. A split-second mis-step can cause a serious burn and/or permanent blindness.
Concerning third-world survival, nothing is more immediately neccessary than clean water. Cholera, dysentery, a wide variety of parasites, etc, plague these countries through poor water quality. Also, deforestation is increasing the soil erosion, loss of topsoil, and desert growth in these areas. The deforestation is sped by rural villages chopping down trees to burn for cooking. A conversion to solar cooking can ease the stress on forests.
The recent earthquake/tsunami troubles in Japan show that even a modern country can make use of improvised solar water purification in disaster-relief areas. Multi-faceted flat reflectors and single-curve concentrators can be easily made from gathered junk. Here are many examples so that we benefit from the research of many previous experimenters (scroll down to see pics):
Wikipedia "solar cooker"
http://en.wikipedia.org/wiki/Solar_Cooker
Solar Cookers International wiki
http://solarcooking.wikia.com/wiki/Category:Solar_cooker_designs
I would recommend using a cast-iron "Dutch Oven". If you get the style that has a concave lid (rather than a dome) it can hold coals on top when using it on a camp-fire (broken wood is usually easy to find after a disaster). They are virtually unbreakable, and should last a lifetime. Since the heat-profile of a solar cooker and a Dutch oven are the same, here's one of many websites with over 1,000 recipes for campfire Dutch oven cooking: http://www.justdutchovenrecipes.com/index.html
The two new things I recently saw are the "Phaeton Array", and also a double-trough concentrator using a single curve (rather than a bowl-shape) on each reflector. Dish-style concentrators are not very difficult to make, however, if you have chosen a double-concentrator style to build, it is easier to make the single-curve reflectors.
The Phaeton is mounted on wheels so it can be rotated to follow the sun easily, and also its made of many flat facets on the main reflector, which focuses onto a low reflector that directs the heat upwards to the bottom of the pan.
For the single-curve reflectors, there is no need to use math to derive a "perfect" parabola (dish) shape. Instead, you tighten cords to slowly bend the shape of the single-curve until the resulting focused light is the size and shape you desire. Mylar peel-and-stick film from an automotive customizing shop (or ordered online) can be applied to something as simple as thin plywood.
Due to the high heat (a good thing!) the smaller secondary reflector may need to be made from polished sheet-metal. It may also be useful to focus the heat onto the bottom of a steel plate for safety and ease of cooking (such as in the Phaeton configuration).
http://solarcooking.wikia.com/wiki/Parabolic_solar_reflectors
