i see that hobbyking sells bare cells and i noticed a warning
WARNING: Soldering Lipoly Cells takes a degree of skill and experience. Do not attempt to solder your own packs if you are not confident in your soldering abilities. No Warranty is implied or given once you have soldered the cell tabs. Please check cells for warranty purposes prior to soldering.
are lipo cells sensitive to heat applied at the tabs that could start a thermal runaway or is it more a factor that you could short the cell?
how difficult is it to solder to lipo cells?
http://www.hobbyking.com/hobbyking/store/__33130__Turnigy_5800mAh_1S_25C_Lipoly_Single_Cell_USA_Warehouse_.html
