msebold
My question is about soldering copper wire leads directly to pure nickel welding tape. Basically, will these soldered connections hold well?
I'm making a 18s/11p battery pack that will draw 60 amps maximum. I seek maximum conductivity and no hot spots in the pack. I am connecting the parallel clusters via nickel welding tape. I would make my series connections using copper wire leads (probably AWG20 braided wire). Basically I would solder a series wire lead directly to the nickel welding tape between each two cells in the parallel cluster. I would use leaded solder which is easier to work with.
One member suggested that I scuff the nickel tape before soldering, to ensure a good soldered connection. This makes good sense, but has anyone tried this? Does nickel welding tape adequately hold a soldered connection?
