SOLVED: Ebike Isn't Doesnt Have Nearly As Much Torque Anymore
pedlar
100 µW
Milwaukee
Hey so first time posting here and I need some help figuring out what's going on with my ebike. It doesn have the torque it once had. And takes forever to accelerate
Motor:
QS273 3.5T
Battery: 72v40ah
Controller: Sabvoton 72200
The controller settings are fine. And I put in a new throttle. What else could it be? The pedal assist cable's disconnected but I don't think that could be it. Could it?
I'm at wits end with it. Not sure if it could be a software or hardware issue.
Do you have a temp sensor? If your magnets weaken due to high temps, your torque will decrease.
I do have a temp sensor. But I’ve disabled motor temp sensor in the settings. I’m thinking maybe my dropout needs to be adjust to be further back. Will let you know how that goes
It helped but not a significant gain. Thinking it might be battery?
Like the amperage opens up at midrange but I’m getting no amperage off acceleration off throttle
But uh, you just said you changed the throttle. Have you tried switching back to the old throttle or is it too much of a PITA?
Update! Reset the factory Sabvoton settings and ran a hall angle. Hall angle was 66 degrees. While mine was set at 120. Now it takes off like a rocket. Thanks !!
