UPDATE: Solved. The cells had already reached the constant voltage phase of charging, so the current was dropping as it should.
Anyone have experience with an iCharger X6 and a Meanwell 24V 750W power supply? Mine seems to work fine but I can't get it to go past 26A when charging just a 2p set of 100AH LFP cells. The power supply isn't even vaguely warm, so I'm fairly sure it's not the issue. I've just never seen anything beyond 26A, and it seems to go up to 25-26 briefly then settle down at 21-22A for the duration.
I tried upping my psu's voltage to its max at 27.66 but it makes no difference.
Here's a screenshot. I don't have temp or balance info, just directly wired to 2p 100AH cells, so I just set capacity at 200AH, and iCharger thinks it's a 1s, which it effectively is.
Cheers.
Cheers.
