Hey Wheazel,
I am not sure what the stock copper weight is nor the weight of the copper I am putting on. I have a stock stator I could weigh and possibly work it out, but honestly, I would prefer to use that time getting it finished.
But at a guess, I would say it has less than the stock wind, by a fair bit, maybe 20%
With that being said, once I pot the whole thing in an epoxy and copper powder mix, I am confident I can extract a lot of heat and therefore significantly increase actual/usable continuous power.
And, I have no idea how I am effecting efficiency, and all the other things that are changing for better or worse. This is a build it and see what you end up with approach! If I can achieve 3kw continuous power at the rear wheel, I will be super happy.
One of the benefits is it will be a sealed motor (at the expense of the complexity of radiators and pumps).
D
