You can use
this page to compare 18650s under different loads.
The Sony VTC6 is the best 3000mAh 18650 available right now. It performs marginally better than a Samsung 30Q. The VTC6 doesn't have as much voltage sag under high loads. The Samsung 30Q is in the middle. It's still pretty good, but a little bit worse than t he VTC6. The LG HG2 is the worst out of these three. Right from the start its voltage sags more than the 30Q, and it sags even more as time goes on. The difference isn't huge though, so don't let it influence you too much.
Unfortunately, the Sony VTC6 is the most expensive of the three. The 30Q and HG2 are similarly priced. Illumn.com has the lowest prices on all three of them at the moment. $5 for an HG2 or a 30Q, $6 for a VTC6.
