LiFeCycle
1 W
Finished product:
Just thought i'd post an update on a sound system i have built for my bike.
Having used an underpowered portable bluetooth speaker @3w, I decided to build a 30w speaker system run off my battery. I bought the following:
And assembled it. Initially, I have glued the speakers to a phone case just to hold them and see how it works. Then, I screwed, and liquid nailsed the bluetooth receiver to the top, and the amplifier upside down on the bottom of the left side of the phone case.
It took 3 or 4 coats of liquid nails to get everything secured in place. I just wanted to get it on with the minimum of fuss and weight. Found something to screw it to, and mounted it.
The output of the bluetooth modules is soldered to where the 3.5mm input socket of the amp is soldered to the board. You can still plug a 3.5mm plug into it if you want. The unit runs on a 12v dc-dc converter in the battery bag. $10 on ebay.
Here's how it looks.
[strike]I learned a few lessons. Don't put the speakers right next to each other. They interfere in a major way, causing you to hear the difference between the left and right channels rather than their actual content. It sounds really weird, and changes depending on the angle you listen. I just cut one of the speakers off and just run one channel so it actually sounds ok. So I ended up with 1x 15w channel on the amp, driving a single 15w speaker with pretty bad bass.[/strike]
<edit>When wired in phase, they sound great together.
It's quite loud though - especially at a standstill. Noticeably better than the portable unit.
But I rode home today at 40kph into a 40kph headwind, and you could barely hear it at max volume.
Overall, it's a cool little unit, which just unclips at the pack and the cord unplugs with a 2.1mm dc jack, and i can put it away if it rains.
[strike]I'm contemplating a build with a car speaker[/strike] to have a bit of oomph and better range. One could be easily constructed with a 200w class d amp, thats about the voltage that they run on your pack voltage without a dc-dc for those of us on 50 -60v.
Apparently this is a 'Class D' https://en.wikipedia.org/wiki/Class-D_amplifier - i.e. one in which an analog signal is converted into a high frequency square wave, which a mosfet can switch more efficiently. It requires less heatsink per watt than the one i used on my first build.
Then I would pair that with a car speaker over the back wheel.
Edit: Now that i've run the 30w one for a bit with a proper enclosure, the car speaker seems totally unnecessary.
