Hi All,
Just about finished setting up my first Ebike Project. This is setup for a 23km commute to work. Top speed 50km/hr. Hauls up big hills nicely at 35kph.
Parts sourced and Torque Arms were designed and made up by EVLAB.co.nz. Really helps to have someone who knows what they are doing help you into this.
Ebike Parts Used:
2x 36v 10ah ping battery with 2x chargers
Rear 9 continents 2808 wind Motor
Infineon 12 Fet Programmable Speed Controller
Spoke Set
Rear Rim ALEX DM24 26" - 36 Hole
9 speed cluster cassette
Custom designed Torque Arms with shims and spacers from EVLAB
Programming Cable For Speed Controller
Battery Bag
Seat post Mounted Carrier Rack
Twist Throttle
Regen Button
Three Speed switch
Battery Extension Leads
Other Parts Used:
Magicshine LED bike light 1600 lumen
front tube mount mud guard(union)
hookworm tyres dual ply
Maxxis freeride tubes
Pipe clamps x2
Exhaust pipe Clamps 40mm & 50mm
Alloy Tube
Butinol rubber
Loctite
To do:
Voltage adaptor for lights and accessories
Key Switch
Motor Cable extension
Proper Controller mount
Hope this is useful for anyone out there looking to setup an enduro!
Ebike Parts Used:
Spoke Set
Battery Bag
Twist Throttle
Regen Button
Three Speed switch
Other Parts Used:
Pipe clamps x2
Alloy Tube
Butinol rubber
Loctite
To do:
Key Switch
