Speed limiter
Garry1971
Hi does anyone know how to remove speed limiter on a windgoo electric scooter model b19,it can be done manually but I'm not sure how,
Most speed limiters from Chinese scooters can be removed simply unplugging one connector from the controller. Windgoo, definitely doesn't sound American. It will be a single wire. Not familiar with your model but take a look under the deck and see if there is a single wire connector from the controller and unplug it. Just know that range will decrease with your new found 5mph. Again I'm assuming you have a top speed currently of 15mph and this will get you 20mph but without knowing anything about your model I'm only guessing.
