Kennyken5072
Hi all,
Does anyone know the specification for the QS 273 motor
What I'm looking for are it's limits also programming threshold
For example
Throttle has min voltage standard setting of 1.3v what are max limits
Acceleration ms set to 200 standard what's best setting
De acceleration ms 300 standard best setting
Throttle mid voltage v 2.50 standard what's best setting
Throttle max current A 225 what's best setting
Has anyone found best max power for the above I've been testing various settings and like to see if I'm on the right track it would help if there's spec sheets with all the min and max settings in the programme side and also what the motor is actually capable of I'd guess 8000w you could increase by 20% as all powered vehicles are always set around 60-80%. I was test technician testing diesel engines so understand but electric am a newbie and trying to learn..
Be very grateful for advice
Thanks Steve
For example
Thanks Steve
