paultrafalgar
Sterling Engine as Ebike Power Source
http://www.sunpower.com/lib/sitefiles/pdf/publications/Doc0094.pdf
"The high specific power (>90 W/kg) and high efficiency (>30%) of the convertor makes it attractive
for use as a fuel-fired battery replacement. This application is particularly promising because batteries have
extremely low energy density. Even lithium-ion batteries have an amazingly low energy density compared to liquid
fossil fuels; approximately 150 times less.
Thus even considering the efficiency of the convertor combined with a burner, the energy density of a fuel-fired
battery would be significantly greater (more than an order of magnitude) than that possible with batteries. Such a
devise can also be quickly refueled compared to the slow process of recharging batteries."
Imagine this device, mounted on a towed trailer and the dish steered in realtime to point at the sun. Connect the output to an ultracapacitor (and/or battery)on your ebike. Alternatively, station the solar sterling engine at home and charge your batteries. Use another such sterling engine heated by burning bioethanol on the ebike.
