Yeah, discussed already.bataanjr said:Cromotor V2 Clone.
http://www.aliexpress.com/item/5000w-electric-bike-motor-5kw-brushless-electric-bike-motor-5kw-e-bike-hub-motor/1401327505.html
Both electrical and thermal insulation...I'll be interested to see if you get any better thermal performance from this vs a stock vented HS35xx.parabellum said:Silicone sealant everywhere, it holds wires in place and gives additional insulation, no, i just love this mess.
You are right if I would go air cooling, would I?Cowardlyduck said:Both electrical and thermal insulation...I'll be interested to see if you get any better thermal performance from this vs a stock vented HS35xx.parabellum said:Silicone sealant everywhere, it holds wires in place and gives additional insulation, no, i just love this mess.
Cheers
Not totally necessary, notice, I have sealant on 1 side, were those interconnections of different phases over each other are. Those wires move by constant temp changes or what ever other reason and hypothetically rub on each other, damaging insulation. Other factor is erosion caused by oil and particles in it. Finally, satisfaction of my paranoidal concernsCowardlyduck said:Now it makes sense.
Putting sealant on the windings isn't really necessary for oil cooling is it?
I plan on doing the same to my HS4080 at some stage.
Cheers
I am looking to get 14" moped rim locally, so Im going "mathematically" for under 80kmh on flat. Will be easier then 94kmh wot before, I hope. :lol:nicobie said:36s!
We need to start a lottery on how long it will last. :wink:
Oh, I almost forgot 66.8 kmh on flat 96V 1800w back wind and 62 kmh 95.5V 2200W on way back, against wind, so it is about same.Tench said:Thems looking like impressive numbers, 37mph on 22amps! be interesting to compare it directly against some of the std wind crystalytes.
