auraslip said:Is the imax really named after the creator?
Ykick said:Behavior I've noticed with my iChargers is that it becomes unstable and delivers weird readings if the input supply sags and/or you attempt to pull max power through the device. Make sure your input supply is hanging stiff and perhaps try turning down the charge amps a bit to see if things settle down?
Dunno how related this design is to iCharger but the button layout looks identical.
neptronix said:Ditto. What i have found and what i have read is that some specs are a tad overrated and you should really stay just a hair below them.
IE mwkeefer ran his 1010b+ at i think 17.5v input, when the max input rating was 18v, and he blew his. O_O
Or if i run mine anywhere near the wattage rating, the fans go bezerko.
liveforphysics said:neptronix said:Ditto. What i have found and what i have read is that some specs are a tad overrated and you should really stay just a hair below them.
There would be no problem running close to the limits if you had a perfectly stiff power supply and little short cables.
The problem with running it close isn't that the voltage while running is close, it's the big voltage spikes it gets every time current starts and stops when people are running long wires or crude power supplies or bad connections etc.
neptronix said:liveforphysics said:neptronix said:Ditto. What i have found and what i have read is that some specs are a tad overrated and you should really stay just a hair below them.
AHA...![]()
So there isn't really much in the way of safety margin there.
I've noticed that with Chinese stuff; the specs you see are what you get in a best case scenario. No wiggle room built in.
