Hello all!
I recently acquired Tongsheng TSDZ2B2 (500W) with battery and SW-M58 (on the site it actually says SW2-M58).
And I'm encountering some problems;
The speedometer doesn't work out of the box, no life what soever. The magnet is hitting the arrow and there is about 5mm clearance so I do not think that this is the problem.
But then the actual problems with the display;
The manual states that there are settings from P00 to P17 but, the fact sheet is here: LCD Display SW-M58 - Sciwil
But I have some problems (to put it lightly);
P00 is missing, which is reset, I cannot thus reset the device
P05 should be the count of the assist levels. This doesn't seem to save properly but somehow we at some point managed to change it to 3 and then back to 5.
P06 should be the wheel size, but is a binary option of 0 or 1 which somehow changes the battery level from 60 to 100 and other way around, no idea what this is.
P07 and P08 are missing, but there is four number (0000) code here. I somehow found from some AliExpress site that the password for the unit is 1919, trying this actually opens up P07 and P08;
P07 is value from 5 to 35, but manual states that this is number of motor magnets for gauge? What does this mean? And the manual says that this is value between 0-100. I would assume that 5 to 35 is actually the wheel size as the default was 27.
P08 is value from 0 to 100 (in Km). Manual says that this is some speed limit, which is fine I guess? Default value is 60.
P09 is supposed to be binary 0 or 1 for direct start or kick start, this is hexadecimal 4 - field (from 0000 to FFFF) value that cannot be saved.
P10, P11, and so on up to P17 are missing, cannot find a way to enter these.
So, I presume my manual is wrong (the device is SW2 instead of SW) or my software is corrupted, any advice how to pursue this further?
The bike itself kind of works. The assist works, the "gas trigger" works. Just that the speedometer doesn't and I would assume it to be either the missing wheel size or magnet count?
Any help is greatly appreciated!
Brgs,
Sampo
Brgs,
Sampo
