The origin of this project was the intended conversion a 1947 Swallow Gadabout scooter with a 122cc Villiers 9D two-stroke engine to electric power. However on reflection, it seemed a shame to mutilate a rare survivor, so it was decided to build an updated copy of the original design and incorporate front and rear spring suspension.
Construction began with the acquisition and then the dismemberment of an old pit-bike frame, which provided a head-stock and rear pivot bracket for a swing-arm. A second-hand set of Honda Z50R telescopic front forks, a Z50R swing arm and a pair of 270 mm shocks completed the planned suspension requirements. The original wheel-base of 52 inches has been maintained and combined with a fork rake 25 degrees provides satisfactory handling.
The frame is made of 45-mm diameter round steel tube which is dimensionally the same size and shape as the original Gadabout scooter and the handlebar arrangement has also been copied. Original 1940s parts such as a Villiers headlight, a Smiths chronometric d-shape speedometer and old chrome handlebar levers are also intended to help maintain the scooter’s vintage appearance.
The two eight-inch diameter wheels are Chinese copies of the original Honda Z50R wheels and will be fitted with period-looking 8 x 4.00 tyres. Cable operated front and rear 5-inch drum brakes are similar to the original arrangement except that the rear brake is now applied by means of the left-hand handlebar ex-clutch lever. The scooter’s rear bodywork will be aluminium panels on a steel frame and is designed to be interchangeable with the original Swallow Gadabout’s steel bodywork.
A basic 24v electrical drive system consists of two 12v 18AH SLA batteries connected to an e-bike YK31C controller and a 24v 350w geared brush motor. The transmission consists of a roller chain (#420) with a spring tensioner, driving a 16-tooth motor sprocket connected to a 37-tooth rear sprocket.
