Talaria Sting emoto dirtE bike
efMX Trials Electric Freeride
🚴‍♂️ Mega poster
Data sheet
Chassis - Swing Arm Material 6061 T4 & T6 Aluminium Alloy
Chassis Construction MethodForged by 8000 tons pressure
Rear Shock Absorber Fastace with Linkage
Tire Size Front 70/100-19 / Rear 80/100-19
Max Range 76km @ 45 km/h
Max Load100 Kg
Speedometer TFT Digital
Motor Rated Voltage 60V (DC)
Motor Rated Power / Peak Power 3000w / 5800w
Motor Rated Torque / Peak Torque 8.5 n.m / 31.8 n.m
Motor Shaft Output Torque @ 1000 RPM 29.5 n.m
Motor Peak Efficiency 96.60%
Motor Type PMSM (Permanent Magnet Synchronous Motor)
Motor Mounting Position Center Frame
Motor Weight 7 Kg
Motor External Diameter 180mm
Motor Axial Length130mm
Motor Cooling Method Air Cooled
Controller Type FOC
Controller Weight 1.6 Kg
Controller Dimension 240mm x 110mm x 50mm
Controller Peak Efficiency 98.50%
Controller Traveling Wave
Current 85A
Controller Highest Temperature 100 °C
Powertrain Rated Rotation Speed 4300 RPM
Powertrain Range of Rotation Speed 0-5300 RPM
Powertrain Peak Efficiency 98%
Powertrain Range of Efficiency (≥80%)1.4 nm - 22.5 n.m
Battery 60V 38.4A Lithium LG Cells
Battery Life Time 800 Cycles before battery looses capacity
Charger 10A 60VCharging Time 4 Hours
USB Connection USB 2.1A Single Type C
Chassis Weight 9.5 kg
Chassis Surface Anodizing Paint Treated
Headlight LED
Fork Manitou (optional) / RST - DNM (Standard)
Wheel Type Spoke Wheels 19x1.6
Tire CST
Top Speed 75 Km/h
Brakes 4-Piston Caliper Hydrolic Brakes
Brake Disc 203mm
Net Weight 58 Kg
Vehicule Dimension 1870mm x 780mm x 1040mm
Min. Ground Clearance 270mm
Wheel Base1260mm
ebikezilla.com/en/talaria/40000-electric-dirt-bike-talaria-sting-black-tl-001-bk-talaria.html
elektro-mall.ru/talaria
vargtrading.no/produkt/stalaria-sting/
"Seasoned engineers, new brand , new model aiming to improve on the market leader: larger battery capacity, taller seat height, more ridgid chassis, wider rear tyre as standard, advanced data on lcd display, no weak belt drive system, bring it on #talaria #Sting #ebike #bikelife ..
Talaria Ebikes
https://m.facebook.com/463616270454422/
efMX Trials Electric Freeride said:
TALARIA OEM PARTS :
Gearbox Assy :
ebikezilla.com/fr/spareparts/930009-pieces-oem-talaria
It would be interesting to see if that gearbox is adaptable to the sur ron motor to eliminate the jack shaft.
It shows a permanent "legal" (engraved, rivet or welded) VIN label on chassis. :bigthumb:
part # 52032-56000-000 https://ebikezilla.com/fr/spareparts/940000-chassis
Production bikes I see have a 17 digit alphanumeric engraving on the headpipe.
Who is the actual manufacturer of the Talaria? Looking at https://www.talaria-motor.fr
I don't believe its them. Maybe some former Surron people?
Sure we'd like to find a Surron (Luna) alternative.
Talaria power tech in Chongqing china is the manufacturer (some previous surron engineers;) .. dealers spreading like wildfire across europe etc..
check with built Ebikes for USA ??
builtebikes.com/collections/ebikes/products/talaria-sting-46mph-ebike-1
dan974 said:
Does anyone have a link to order quantity with the manufacturer plz
You can try contact thru the manufactures facebook listed phone number, I expect they will also have alibaba or aliexpress listings when production catches up with demand for the new bike. Sur ron was available direct in 5 and 20 bike lots.
https://m.facebook.com/Talaria-Power-Tech-105913535087819/
