Pyrotrons
Thanks to each of you for such a useful forum.
For my first-time build, I've got an older model Trek 820 that I'm
converting
. I need to cruise at 35Mph, but my battery options are limited to either 36V OR 72V. Already, I seem to have found myself between a rock and a hard place. Am I overthinking this?
36V:
25Mph seems to be a generally-cited max speed. Is procuring a low-turns-count motor my only option (Kv change) to get to my target speed of 35Mph? Currents will start getting high... 60A? 80A?. I assume that high-current controllers exist that are NOT rated for higher input voltages... because higher voltage MOSFET's would be a waste of power (higher ON resistance, Rds_on). I don't want to spend money on a custom-wound motor. Very little about this option seems practical.
72V:
The major issue here seems to be the 135mm drop-out width of my Trek 820. I'm unaware of any 72V motor with a drop-out other than about 150mm. Forcing the seat and chain stays out by 15mm doesn't seem too bad... I've seen it recommended for steel frames like this... what can of worms might I be opening?
Running 72V into a 48V hub motor?
I can drop a 48V hub motor right into my Trek. Provided that I can solve all thermal issues (by oil-filling, replacing with Teflon wiring and adding heatsink), where do I hit the point of diminishing returns when over-volting a 48V hub motor such as http://www.ebay.com/itm/48V-Electri...254627&hash=item339dcf9fe8:g:QG4AAOSwXetZUM1p
By "point of diminishing returns", I'm referring to saturation, eddy-current and hysteresis losses. Am I in uncharted territory with finding lamination thicknesses of various China motors? Overthinking. Help.
Regards,
- Pyrotrons
36V:
72V:
Regards,
- Pyrotrons
