safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
Tenergy NiCad SubC's Report
Just thought I'd report on my Solderless Tubes using Tenergy SubC NiCads.
First, the Solderless Tubes work great and franky I've not had any problems with them. It puzzles me why people haven't done this all along. The secret is the combination of screw and spring combined with the use of copper to make the electrical connections.
The NiCad SubC's are rated as 10C and I can disconnect my SLA's and test them at that rate and they seem able to deliver that for a while. When you do that they heat up. I normally run the SLA's in parallel with the SubC's and so the "C" rate is more like 3-4 "C" so they never get warm during use. So far the cells I'm testing are all charging and discharging successfully and the starting and ending voltage is more or less balanced for each set.
The only unexpected thing I've found is that the self discharge rate seems pretty high. I'm finding that you lose a lot more than the standard 1% per day and are losing more like 5% or more like 10% in a day, at least the first day. I've found that I can usually top off the cells a little with an extra five minutes of charge to get that last bit of extra before riding.
Long term testing will take... well... time... but I've used them for about 200-300 miles so far and they seem okay.
If you want to consider a low priced alternative to the other battery options you might look into:
http://cgi.ebay.com/96-NiCd-Sub-C-2400mAh-Batteries-for-PowerTools-Flat-Top_W0QQitemZ330198582341QQihZ014QQcategoryZ40975QQtcZphotoQQcmdZViewItemQQ_trksidZp1742.m153.l1262
Dirty_D:
If you manage to see this, maybe you could post what your performance has been with these cells since I know you bought a batch too.
The nice thing about Solderless Tubes and Nicads is that there's nothing that can easily break and you don't need all the Balancing, LVC and other assorted BMS hardware. NiCads are pretty durable it seems and the high "C" rates of the SubC's allow for more freedom in their use. I'd still suggest running any battery at below their maximum because all things prefer to be run in moderation and not excess.
![Arrow :arrow: :arrow:](/sphere/data/assets/smilies/icon_arrow.gif)
Dirty_D:
