Ypedal
100 TW
Wrong.. get the meter.
You want to buy one for me? :lol:Ypedal said:Wrong.. get the meter.
You don't follow my threads THAT closely obviously.Ypedal said:Safe's situation of his SLA sagging more than his Nicad, is because his sla's are worn out, still usable, but not a true reflection of what good healty SLA's do.
Thanks.Riles said:Hats off to you, safe.
And given the way discourse happens around here if I did use the lightbulb test then people will begin a long sequence of doubting the accuracy of my testing methods:D-Man said:You don't need the fancy meters to measure capacity.
My next bike will get 240 NiCad cells and no SLA.
safe said:I ran the NiCads all summer... no problems.
My next bike will get 240 NiCad cells and no SLA. That will give me about 30 miles range at full power. Weight will be 35 lbs for 634 Wh.
NiCads are cheap... about $0.40 per Wh... but they are not as light as something like these LiPoly cells but those cost around $0.70 per Wh and they are more at risk for problems. NiCads are the most proven "old school" way to get power while also having long life.
Don't forget you have to build the solderless tubes... that's more work than many will want to do.
For a lot of people it's probably easier to just buy the LiPoly.
I just like the idea of the NiCads being very durable and idiot proof. It's a big enough investment to want to have it last a long time. For pure performance you would be better to do other things. I might alternate between the "distance pack" (NiCads) and a "racing pack" (LiPoly or other) for the speed runs. When logging a lot of regular miles the NiCads seem to hold up well.
Battery decisions are always hard.
I have 6 chargers at 24 volts and 1.5 amps. This means I'll have to charge in two stages. (12 sets to charge) So rather than one hour between 30 mile rides I'll need to charge for two. Either that or buy more chargers.D-Man said:How many battery chargers for this?
So where did you buy them and how much did you spend?johnws6 said:The cells i have now being built into packs can do just that. If you search ebay well enough you can find the same sanyo n3000cr cells i have for about $ 400 per kwh.
safe said:So where did you buy them and how much did you spend?johnws6 said:The cells i have now being built into packs can do just that. If you search ebay well enough you can find the same sanyo n3000cr cells i have for about $ 400 per kwh.
How many are you using?
safe said:NiCads are cheap... about $0.40 per Wh... but they are not as light as something like these LiPoly cells but those cost around $0.70 per Wh and they are more at risk for problems. NiCads are the most proven "old school" way to get power while also having long life.
Bobocop said:safe said:NiCads are cheap... about $0.40 per Wh... but they are not as light as something like these LiPoly cells but those cost around $0.70 per Wh and they are more at risk for problems. NiCads are the most proven "old school" way to get power while also having long life.
Where are you finding NiCads for $0.40 a piece ?
I have been browsing around the net for a few days now looking for something for my build (cheap, but lighter then sla's) and i can't find any reasonable one for under $3 a piece.
mind you i can't afford to buy 300 of them, i want to buy a few here and there untill i have enough for a pack,
but even packs that iv'e seen go for close to $3 a cell.
So again where are you getting them for $0.40 ) (if you don't mind)
Edit: I can't find the Sanyo that johnws6 is using for less then $8.50 a cell --> http://www.onlybatterypacks.com/showitem.asp?ItemID=11521.22
Bobocop said:Where are you finding NiCads for $0.40 a piece ?
Wow! That was one awesome deal!johnws6 said:I bought 300 N3000CR sanyos brand new for $320 shipped.
pwbset said:If you guys are dealing with 100s of SubCs anyway then why on earth wouldn't you just re-purpose the Sony/Konions that marty and DocBass are selling. Your price per watt/hr is going to be cheaper than those NiCads and you'll get lithium that doesn't need balancing and weighs a lot less and is a lot more environmentally friendly to boot. Just something to think about.
