Yeah, the crankarm issue on tandems carries its own set of complications when it comes to mid-drives. But I was actually more curious about how you mounted the motor to the frame: the downtube on the standard upright bikes these mounting kits are made for is pretty much absent on a delta trike, and there are also no chain stays behind the bottom bracket shell to fasten to. Those are both mount points--in addition to the bottom bracket itself--the mid-drive kits I've looked at have relied on. So how'd you mount the motor, i.e., how does it attached to the bottom bracket and frame tube(s)? Any further pics/documentation you can point me to?
