The best winding motor for 300A peak
patrik5504
Hello
I'm going to build a new ebike, the first one was a middrive with a qs205 motor and I push 300A peak from the battery. now I want to build an ebike with a qs 205 in the rear wheel. I use 22s10p molicel p42a, I also plan to pull 300A peak but I don't know which motor winding to choose for the best performance. I am deciding between 3t and 4t. 3t has less motor resistance, will it be a better choice? or will 4t be enough? I want to ride in the forest and on the roads. with such a large current, I will have enough torque even at 3t. I know that the motor will heat up quickly, I plan to add atf oil as well.
