efMX Trials Electric Freeride said:how about using straight pull spokes..
& making your own spoke bends at custom angle as needed..
alsmith said:efMX Trials Electric Freeride said:how about using straight pull spokes..
I had vaguely thought of this but haven't seen straight bike spokes. I'll have a look, I've got some spokes to try the bend but the bend is very close to the mushroom end so may not be too easy to bend accurately.
Thanks!
MadRhino said:TC motors are not so happy in a large wheel. That is probably the reason why they don't supply spoke length for larger than 26". Then, if your bike frame can clear big tires, you can achieve a 28" OD wheel with a 26" rim, using tires 2.5 and up.
Aren't the spokes smaller gauge on the TC than those used on the 5300, 5400 etc. favoured by Crystalyte? Would this be a factor?mvly said:MadRhino said:TC motors are not so happy in a large wheel. That is probably the reason why they don't supply spoke length for larger than 26". Then, if your bike frame can clear big tires, you can achieve a 28" OD wheel with a 26" rim, using tires 2.5 and up.
Actually I think it would help if they go with a larger diameter rim. I had mine in 26 inch and the bend on those cause a few spoke to break. It was probably due to the chinese quality, but then again I don't think it was helping having them on such small diameter rims. With larger rims, or at least rims with proper angles on the nipples, you can actually do fine.
