safe
1 GW
- Joined
- Dec 22, 2006
- Messages
- 5,681
Computers are cheap and powerful. The fact that they are not part of the electric vehicle so far simply says that the industry is not mature yet, but eventually one would expect them to be used.
Here's how I would see them used:
First, the battey suppply is made up of cells. Depending on how you assemble the battery pack, in series or parallel, you can get any combination of volts and amps that you might need. Some battery chemistries are very sensitive to overdrain, low voltage, overcharge, and other various problems. If each cell were individually connected into a switching circuitboard and that board was then connected to a computer you could provide a whole range of services by exploiting the power of the computer.
1. Throttle control could be managed by the selection of how many and in what way the cells are combined to supply the needs of the motor.
2. All the critical cell management duties could be monitored by the computer.
3. Other things like measurement of the system (like all the usual amps / volts / watts) could be provided by the computer to a display.
The advantages would be:
1. 100% energy efficiency. (verses 95% for PWM controllers)
2. Programmable Powerband. (you could configure your electric vehicle for maximum range or power or something in between)
I could envison various preprogrammed powerband configurations that you could select from a menu before you rode. Maybe you might select "hillclimb" or "long range" or "top speed" or "fast cruise" or some other option.
